Set comment color scheme default?
I'd like to change the font/colors/etc properties of the font text box so that it stands out a little more. Right now, I have to do this by manually changing its properties with the color tool/etc and then copy/paste it wherever I want to add a comment.
I'm wondering if there is a config or something in the LabVIEW INI file that will allow me to change the comment properties so that I don't have to manually do it myself everytime I want to add a comment. Anybody know?
If you have the OpenG VIs you could open the VI located at LabVIEW 8.2\user.lib\_OpenG.lib\string\string.llb\Comment__ogtk.vi and change the color and font of the comment on the block diagram. That VI is just a merge VI that contains a comment. You could make your own merge VI if you didn't want to change the OpenG one.
Yes, I have that, but I'm one of those "double-click anywhere and start typing"-type person. I guess I'm looking to save myself some mouse clicks. ;)
