FieldPoint IO Point dosen't work in .exe file
I am working with FieldPoint. Everything work fine, until I built the .exe file. When I click on the FieldPoint IO Point I see the browse ... But when I select it there is a pop up window appear for 1 sec then it disappear. I can not select the channel. Can anyone tell me how to fix this?
THank you,
Thang Nguyen
This is the project to build .exe file, I use only one control which is the FP IO point. I can not open to select it.
I use LabVIEW 8.2.1.
Please check it for me.Highly appreciate for your time,
Thang Nguyen
  • 1 month later...
Thang,
You need to add a Fieldpoint target inthe project. This will allow you to add cFP channels.
There is a knowledgebase on NI discussing this. You can find it here (http://digital.ni.com/public.nsf/allkb/B2C...6257241006D7C77).
After you add the cFP in the project, MOVE the "Test.vi" under the cFP and open it. This will allow you to browse to the channels of the cFP.
I hope this helps.
Regards,
Ashish
