Michael Aivaliotis Posted May 24, 2007 Report Posted May 24, 2007 Does anyone know of a way to add a folder of files to a LabVIEW project using filtering? For example, I currently have a use case where my folders contain svn subfolders which you don't really want shown in a project tree. Quote
PJM_labview Posted May 24, 2007 Report Posted May 24, 2007 As far as I know, you can't. You have to delete the svn folder after you add the folder (from the project tree). Also, if your folder change on disk you have to repeat the process (delete folder from tree view, add it again, remove svn entry). This is quite painfull. PJM Quote
LAVA 1.0 Content Posted May 25, 2007 Report Posted May 25, 2007 Your question reminds me of this post: What's green, hangs on a wall and whistles? Quote
