Ton Plomp Posted May 26, 2007 Report Posted May 26, 2007 QUOTE(Thang Nguyen @ May 24 2007, 07:24 PM) Please give me some advices. They are driving me crazy. Make your customer clear that you want to do a short test (5 mins) or something without the firewall, or try to open the firewall for your executable. Also what make is your firewall off? Ton Quote
Mellroth Posted May 26, 2007 Report Posted May 26, 2007 QUOTE(Thang Nguyen @ May 24 2007, 07:24 PM) One of the problems is the connection (ethernet). I ping the IP address of the device. It replies well. But in LabVIEW it cannot connect.Is there anything relating to the firewall? Because this is client's computer, I does not have permission to change the firewall set up. Hi, when you say ethernet, do you mean you can't connect with VI-Server or TCP/IP or...? If you are using VI-Server, you might want to check that the application is using the correct VI-server port and that access is enabled. Check the application ini-file, so that you have the TCP server enabled: server.tcp.enabled=True for other options, have a look at the Wiki: http://wiki.lavag.org/index.php/LabVIEW_configuration_file.VI_Server' target="_blank">http://wiki.lavag.org/index.php/LabVIEW_co..._file.VI_Server /J Quote
