Porting of Labview 5.1 application LV 8.0
Hi All,
Can the application developed in Labview 5.1 be ported in LV 8.0?
I'm not able to achieve the same.
Please help me in resolving this issue.
Thanks in advance.
This shouldn't be a problem, make sure you have backup copies of the code since saving 8.0 will be very hard to open in 5.1.
What is the problem you experience?
Could you post the VI with the problem?
Ton
VIs can be opened in newer versions, but only if they were saved with their block diagrams.
If that's the case, then you will have to find the original VIs with the diagrams.
