Achtu Posted March 14, 2025 Report Posted March 14, 2025 I have a 2D array and I would like to replace the eleventh column with the lowercase of the fifth column. I understand that it is recommended to use Array Split / Replace Subarrays and my question is, am I using it correctly? And is there any other way? Thanks in advance. Question.vi Quote
Mads Posted March 15, 2025 Report Posted March 15, 2025 You do it right yes, but just use the method you used at the bottom. It is more simple and just as "in-place" as the top-method. If the number of rows were huge and you mainly needed to save memory it might make sense to convert and replace one element at a time instead (avoiding a full copy of the column to be converted, which you still have in your two solutions (verified quickly using ArrayMemInfo...)), but that would be a different code. Quote
