Eugen Graf Posted June 15, 2007 Report Posted June 15, 2007 Have anybody work with WDM ? It's possible to create a driver for capturing video devices and use this in LV? My collegue created an ActiveX (ocx) with Borland C++ and I use it succesfully in LV, but I want to create my own driver without using ActiveX. Any infos? Thanks, Eugen Quote
Rolf Kalbermatter Posted June 16, 2007 Report Posted June 16, 2007 QUOTE(Eugen Graf @ Jun 14 2007, 04:56 PM) Have anybody work with WDM ? It's possible to create a driver for capturing video devices and use this in LV?My collegue created an ActiveX (ocx) with Borland C++ and I use it succesfully in LV, but I want to create my own driver without using ActiveX. I haven't exactly done this but it is not impossible. A WDM driver is however a driver that uses an object oriented architecture. Not something you could directly access in LabVIEW. Also a WDM driver runs in the context of the Windows kernel. What this all means is you will have to write a user space DLL, that does access the WDM driver and provides a standard C API to be called by LabVIEW. Rolf Kalbermatter Quote
Eugen Graf Posted June 16, 2007 Author Report Posted June 16, 2007 Probably it's possible to use DirectShow by .NET assemlies. Any experiance? Eugen Quote
