superslug Posted June 29, 2007 Report Posted June 29, 2007 I am trying to bind single process shared varibales to a front panel object, can anyone tell me if this is possible and if so how? When i look in the data binding section of the properties i can only see network published variables. Quote
communityguy Posted June 30, 2007 Report Posted June 30, 2007 QUOTE(superslug @ Jun 27 2007, 08:40 PM) I am trying to bind single process shared varibales to a front panel object, can anyone tell me if this is possible and if so how? When i look in the data binding section of the properties i can only see network published variables. Hi, I don't know if you've already found the answer but the shared variable does need to be network published in order to be bound to a front panel object. Check out this line from the LabVIEW Help on the Numeric Properties Dialog Box: "Shared Variable Engine (NI-PSP)—Windows Binds the object to a network-published project item or to a PSP data item on the network using the Shared Variable Engine." You can also use Datasocket to do essentially the same thing. Hope this helps! Brian Quote
