Seeking Advice on Multiple Screen GUI with Constant Control
I am seeking some advice in application architecture in a multiple screen user interface with simultaneous acquisition and control.
My goal is to create an application framework that:
1. Is always running data acquisition and control in the background
2. Can display multiple screens that sometimes duplicate indicators and controls (Please see the attached files for an example of what I mean by duplicate controls. Basically, I have a type def of controls or indicators on multiple screens.)
Features:
Each screen shares a common title bar that contains screen navigation and DAQ file save buttons.
Multiple detail screens display indicators and contain controls relative to device control. Some of these are duplicated.
The application must be capable of controlling multiple control loops while displaying various GUI screens for detailed display of parameters.
I am surveying the Lava groups for advice from some more experienced members in how I should create the framework for this application. Maybe a discussion of the pros/cons?
Mainly the feature of a "common title bar" has lead me to the use of a sub-panel or tab control where the VI that contains the title bar has all DAQ and control...
Here are my current ideas:
1. Tab Control (like the attached example)
Good: No need for
Bad: Not scalable, too many "duplicate" controls within the same VI get confusing
2. Sub-Panels
Good: No duplicate controls within a VI, scalable. ?
Bad: Not sure how to avoid over-use of global variables between sub-panel and main controller window (Please advise...). Need to manage launching with VI server property nodes. ?
3. Your ideas here!!!
TIA!
Here is a screenshot for < 8.0
http://forums.lavag.org/index.php?act=attach&type=post&id=6292
I would run all GUI-SubVIs in separately window. No Tabs, No SubPanels. The user have the choice what he want to see, can hide, resize ... If you have SubPanel or Tab you will show "only one" Page or SubVI on the same time. If you use multi windowing, you can show more things on the same time plus it's selectable by user.
Eugen
An example is here in chapter 12 (one of my projects)
http://www.imar-navigation.de/download/tracert-f200_docu.pdf
QUOTE(Eugen Graf @ Jul 3 2007, 06:39 PM)
That's a good example of documentation :thumbup:
QUOTE(tcplomp @ Jul 3 2007, 02:06 AM)
Unfortunately, this is an application that will be run on LabVIEW FDS.
QUOTE(Eugen Graf @ Jul 3 2007, 04:39 AM)
As a feature of the application, I want the operator to view only a single screen at a time, but I appreciate your approach in other instances.
Thus, I am leaning towards using sub-panels which would create a scalable approach...
There are a few "gotchas" to the sub-panel approach that I see:
1. I need to constanly run data acqusition and control (PID loops) in some "main" vi. I could do this in a few ways:
a. Run a "hidden VI" continuously in the background
b. Run a parallel while loop in the "main screen"
2. I have some charts on a screen in which I want to maintain a "history" of the last 5-10 minutes of data. I see two options here:
a. Maintain a circular buffer of data for each chart
b. Load the chart VIs with the main VI, but show/hide them and continuosly populate them with data
Please give me any advice you can think of, I appreciate all of the knowledge!
Thanks
  • 2 years later...
QUOTE(Eugen Graf @ Jul 3 2007, 04:39 AM) [/url]
Thanks
Click this link
http://labviewwiki.org/Image:LV_style.jpg
