remote VISA communication problem
coolaid
Hello,
I'm trying to communicate wit serial and GPIB port of another computer.  My problem is that I see the remote ports in MAX/VISA/Aliases, but not in  the Visa ressource name control.  If I enter manually the port (IP adress + Port) I can communicate with it.
Does anyone have a solution?  Could it be a Visa version problem?
Thank you,
P.S.  I'm using Labview 8.2.1.
You might want to look at the I/O Name filtering. Right click on your control and select I/O Name filtering. Make sure the type of resourse you want to see is not being filtered out.
Dan
