which reference VI accepts different control references?
Could anyone tell me which VI I should use as a control for a supVI, so by which I can pass different typoe of control reference? For example this can be different cluster.
I want to make a general VI which can do samething on different kinds of clusters.
Thank you,
Thang Nguyen
QUOTE(Thang Nguyen @ Jul 19 2007, 04:30 PM)
  Quote
Thank you,
Thang Nguyen
Hi Thang,
You should be able to use an untyped cluster refnum to access generic cluster properties. On the front panel palette (8.2.1), drop a control refnum from the Modern, Refnum menu. Then right click on the refnum and Select VI Server Class..., Generic, GObject, Control, Cluster, Cluster.
That should at least get you access to the Controls[] list of refnums in any cluster via reference.
Something I don't know: is there a way to programmatically determine the original strict type on the refnum once it's been passed to the subvi?
Joe Z.
