JDave Posted August 3, 2007 Report Share Posted August 3, 2007 I checked previous versions and this does not occur in LV 8.0 or 7.1. When you click on a ring or enum a popup list appears that you can select from. As soon as you enter this area with the mouse (sometimes this is instantaneous) the VI Mouse Leave event fires, as long as it is registered for of course. This applies to combo boxes and picture rings as well. http://forums.lavag.org/index.php?act=attach&type=post&id=6516 David Quote Link to comment
orko Posted August 3, 2007 Report Share Posted August 3, 2007 QUOTE(dsaunders @ Aug 1 2007, 04:51 PM) I checked previous versions and this does not occur in LV 8.0 or 7.1. When you click on a ring or enum a popup list appears that you can select from. As soon as you enter this area with the mouse (sometimes this is instantaneous) the VI Mouse Leave event fires, as long as it is registered for of course. This applies to combo boxes and picture rings as well. Confirmed here on LV 8.2.1. On that note, it sure would be nice if enums would fire an event when the user hovers over each selection item... Quote Link to comment
Grampa_of_Oliva_n_Eden Posted August 3, 2007 Report Share Posted August 3, 2007 QUOTE(orko @ Aug 2 2007, 11:00 AM) Confirmed here on LV 8.2.1.On that note, it sure would be nice if enums would fire an event when the user hovers over each selection item... This only support my theory that LV FP object are getting converted over to XControls. So if I wanted to implement an enum drop down, I could fire an event on mouse down and then show a floating picture control to present the list. In that case, I'd expect to see the mouse leave when I go to the picture control. An if I used the picture control as I mentioned, I could use the "mouse Move" to fire events and change the selection highlighting. Wouldn't it be just grand if NI opened up the library of all of their XControls? Ben Quote Link to comment
Aristos Queue Posted August 3, 2007 Report Share Posted August 3, 2007 QUOTE(Ben @ Aug 2 2007, 10:22 AM) This only support my theory that LV FP object are getting converted over to XControls. No. What it should support is a theory that drop boxes are implemented as hovering windows -- just as they are in every other app environment that I know of. The VI Mouse Leave event is correct in that respect ... the mouse is now over a different window. I believe you'll get the same thing with popup menus. QUOTE(Ben @ Aug 2 2007, 10:22 AM) Wouldn't it be just grand if NI opened up the library of all of their XControls? I think we have. When XControls were new in 8.0, there were zero in the palettes and (to the best of my knowledge) that was because none of NIs controls were XControls. I think that remains true for all the core LabVIEW controls. XControls have started showing up in some of the modules and toolkits, but all the ones I've seen are wide open (no password protection). Quote Link to comment
JDave Posted August 3, 2007 Author Report Share Posted August 3, 2007 QUOTE(Aristos Queue @ Aug 2 2007, 08:35 AM) No. What it should support is a theory that drop boxes are implemented as hovering windows -- just as they are in every other app environment that I know of. The VI Mouse Leave event is correct in that respect ... the mouse is now over a different window. I believe you'll get the same thing with popup menus.I think we have. When XControls were new in 8.0, there were zero in the palettes and (to the best of my knowledge) that was because none of NIs controls were XControls. I think that remains true for all the core LabVIEW controls. XControls have started showing up in some of the modules and toolkits, but all the ones I've seen are wide open (no password protection). The popup is 'part' of the control that is on that VI front panel. No matter how it is implemented it should not state that you left the VI's front panel. This is new behavior with LV 8.2 as well. Quote Link to comment
Aristos Queue Posted August 3, 2007 Report Share Posted August 3, 2007 QUOTE(dsaunders @ Aug 2 2007, 10:52 AM) The popup is 'part' of the control that is on that VI front panel. No matter how it is implemented it should not state that you left the VI's front panel. This is new behavior with LV 8.2 as well. The drop box can actually over hang the edge and/or bottom of the window (and it can over hang the top of the window in the case of a very large drop menu). That's why it is implemented as a separate window -- it is actually a different window. You have left the front panel any time you are over these components. You get a VI Window Leave because the operating system has a VI Window Leave. I am very surprised to hear that this is new in 8.2. Very surprised because the implementation of the rings/enums has been this (again, to the best of my knowledge) for as long as there have been rings and enums. I would expect this behavior to go back to 6.1 (the introduction of the event structure). The fact that it doesn't replicate says to me that someone fixed a bug. Probably we weren't detecting other cases where we had left the window, leading to various bugs in other VI use cases (such as someone implementing custom popup menus or somesuch by creating temporary windows). Quote Link to comment
JDave Posted August 3, 2007 Author Report Share Posted August 3, 2007 QUOTE(Aristos Queue @ Aug 2 2007, 09:02 AM) The drop box can actually over hang the edge and/or bottom of the window (and it can over hang the top of the window in the case of a very large drop menu). That's why it is implemented as a separate window -- it is actually a different window. You have left the front panel any time you are over these components. You get a VI Window Leave because the operating system has a VI Window Leave. I am very surprised to hear that this is new in 8.2. Very surprised because the implementation of the rings/enums has been this (again, to the best of my knowledge) for as long as there have been rings and enums. I would expect this behavior to go back to 6.1 (the introduction of the event structure). Looking back it seems like this could easily have caused a Mouse Leave event in other versions. But I hope that this special case was handled especially. And thus hopefully something broke in 8.2 which means it will be fixed in a future version. Because I see no real use for getting that event for entering a control's popup selection area. In fact, for LV 7.1 at least, if you clicked on a ring and then left the VI front panel completely you didn't get a Mouse Leave event. I assume that what really changed is that when a ring was clicked on, further mouse events went to whatever was showing the popup. Now in 8.2 the events are being routed back to the owning VI. So maybe you just need to filter what events are sent. Quote Link to comment
JDave Posted August 5, 2007 Author Report Share Posted August 5, 2007 Thank you very much for such a detailed explanation. I'll start digesting it. Quote Link to comment
JDave Posted August 7, 2007 Author Report Share Posted August 7, 2007 A CAR has been filed on the issue for further investigation by LabVIEW R&D team under CAR ID #4C2ANAK8 Quote Link to comment
