JDave Posted August 3, 2007 Report Share Posted August 3, 2007 This bug seems to start up in LV 8.0. If you click on a color box the selection area pops up. If you press the [Esc] key you will still get a Value Change event with the previous color value. Also, if you enter the popup area and then subsequently click outside of the popup area anywhere else on the panel, you will also get a Value Change event. This does not occur if you do not first enter the color selection area. Quote Link to comment
PJM_labview Posted August 3, 2007 Report Share Posted August 3, 2007 QUOTE(dsaunders @ Aug 1 2007, 05:06 PM) This bug seems to start up in LV 8.0. If you click on a color box the selection area pops up. If you press the [Esc] key you will still get a Value Change event with the previous color value.Also, if you enter the popup area and then subsequently click outside of the popup area anywhere else on the panel, you will also get a Value Change event. This does not occur if you do not first enter the color selection area. Reading your post just jog my memory. Additionally the value change events fires twice (when only one is expected). http://forums.lavag.org/index.php?act=attach&type=post&id=6517''>http://forums.lavag.org/index.php?act=attach&type=post&id=6517'>http://forums.lavag.org/index.php?act=attach&type=post&id=6517 PJM Quote Link to comment
Aristos Queue Posted August 3, 2007 Report Share Posted August 3, 2007 I don't see a CAR number. Has someone reported this to NI? Quote Link to comment
JDave Posted August 3, 2007 Author Report Share Posted August 3, 2007 QUOTE(Aristos Queue @ Aug 2 2007, 08:29 AM) I don't see a CAR number. Has someone reported this to NI? Doing that right now. Wanted to get some independent verification first. Quote Link to comment
jaegen Posted August 3, 2007 Report Share Posted August 3, 2007 Something similar to this was reported here. (The "Value Change" event fires twice for normal colour selections) CAR: 42FC9DIQ Jaegen Quote Link to comment
