silmaril Posted August 7, 2007 Report Posted August 7, 2007 ZITAT(Marginal @ Aug 6 2007, 03:08 PM) Prompt please how to control the level of record of the line input of sound card with LabView? You should be able to do this with only two express VIs. "Acquire Sound" and "Amplitude and Level Measurements" should do the trick. Of course you could the same using "real" VIs as well, which is just a little bit more complicated. Quote
