VegHead Posted August 7, 2007 Report Posted August 7, 2007 Trying to use active X to control MAX. Need to get to the Reset Configuration function found under the tools > NIDAQmx configuration > Any idea what class this is found in? Any idea where I can find Help for active X and MAX? Thanks, Dave Quote
i2dx Posted August 8, 2007 Report Posted August 8, 2007 QUOTE(VegHead @ Aug 6 2007, 07:25 PM) Quote Trying to use active X to control MAX. Need to get to the Reset Configuration function found under the tools > NIDAQmx configuration > Any idea what class this is found in? Any idea where I can find Help for active X and MAX? Thanks, Dave If you want to reset your device you don't need ActiveX, there is a reset device VI in the DAQmx lib: C:\Programme\National Instruments\LabVIEW 8.2\vi.lib\DAQmx\configure\system.llb\DAQmx Reset Device.vi Unfortunately this VI is not in (my) DAQmx-Palette - but I can remember it was there in LV 7.1.1 ... Quote
VegHead Posted August 8, 2007 Author Report Posted August 8, 2007 QUOTE(i2dx @ Aug 7 2007, 01:37 AM) Quote If you want to reset your device you don't need ActiveX, there is a reset device VI in the DAQmx lib:C:\Programme\National Instruments\LabVIEW 8.2\vi.lib\DAQmx\configure\system.llb\DAQmx Reset Device.vi Unfortunately this VI is not in (my) DAQmx-Palette - but I can remember it was there in LV 7.1.1 ... I wish it were that simple. The Reset NI-DAQmx Configuration appears in MAX at Tool > NI-DAQmx Configuration > Reset DI-DAQmx Configuration, completely clears out all tasks and global channels. My goal is give my users an interface that will give them choices between loading a set of Default Tasks, use the current tasks or loading a previously saved Configuration of Tasks. The DAQmx Import function merges the incoming tasks with any that currently exist. I can't rely on them to delete the unneeded tasks. So I'm looking for a way to delete all the tasks and global channels for the instance when the user wants to load the default or previously saved settings. Thanks, Dave Quote
