error 1108
noir_desir
Hello everybody,
I have got a problem with xml string, in fact à vould like transmis this xml trame :
And i would use
I have got problem
-1108...
I don't a fault in my code...
Thank you
  1. You didn't give the text, just an image of the text.
  2. You didn't give us the VI you were proposing. We've no idea what the cluster is that you have wired that must match the XML.
Your XML has many, many problems.
e.g.
<string>
<name>adresse</name>
<val>fabio....</val>
</string>
That is not a string, it is  cluster of "name" and "val". It cannot be converted into a LabVIEW string type if that is what you have wired to the the primitive.
Generate the XML from your cluster that you have used with the unflatten then compare with what you have in your XML text.
Edited by ShaunR
4 hours ago, noir_desir said:
hello
I'm sorry. i use crio to  transmis my cluster (vi envoie) (transmission)
and receive in my program (reception)
transmission.zip 313.41 kB · 1 download reception.zip 103.43 kB · 0 downloads
When you send the message you encapsulate the message as a cluster of string and variant. You don't seem to unwrap the variant from the name/variant cluster in the receiver.
What I expect to see is  something like this in the receiver:
11 minutes ago, noir_desir said:
hello,
Cluster is open before (in message machine) i just take variant .
The variant in your image is a cluster, not a string.
