Convertir. vi
8 hours ago, jro1952 said:
Hello, I'm interested in adding maps to LabVIEW and I downloaded labview-gmaps-master.zip, but I can't use it; it's for newer versions. Could someone convert the package for version 2010? Thank you very much. labview-gmaps-master.zip 563.51 kB · 2 downloads
You should contact the developer. It may use features not available in earlier versions and it is a source control nightmare maintaining subtly difference versions.
  • Thanks 1
On 20/6/2026 at 4:55, ShaunR said:
Deberías contactar con el desarrollador. Puede que utilice funciones no disponibles en versiones anteriores y mantener versiones con diferencias sutiles es una pesadilla en cuanto al control de versiones.
