How would you review AI-generated illustrations in engineering documentation?
An AI-generated illustration can make a technical document easier to read while quietly introducing details nobody intended to specify.
Consider a training document explaining the general layout of a test station. An illustration shows a computer, an instrument enclosure, and a device under test. During review, someone notices an extra connector on the enclosure and a cable that appears to terminate at the wrong device.
Those details matter because a reader may interpret them as part of the procedure.AI-generated conceptual illustration of a generic workstation layout. Equipment details and connections are intentionally omitted.
A practical approach would be to define the illustration’s purpose before generating it. Is it introducing the setting, identifying real equipment, or explaining a connection? Each purpose needs a different level of review.
For example, a tool such as GPT Image 2.6 could be used to explore a general workstation illustration. The brief could keep the scene deliberately simple:
“Create a flat editorial illustration of a generic electronics workstation with a computer, a closed instrument enclosure, and a small device on the bench. Use simple shapes and blank surfaces. Omit visible ports, cable connections, numerical readings, and equipment labels.”
That gives the illustrator a limited task. The document’s actual connection instructions would still need their own verified drawing or photograph.
A review could then cover three questions.
What could a reader infer from the image?
Check every visible detail that could be interpreted as an instruction: cable paths, connector locations, indicator states, screen readings, and equipment labels. If a detail has no basis in the document, remove it or replace the illustration with a verified source.
Does the caption explain its purpose?
A caption such as “Conceptual illustration of a workstation layout” helps establish context. Place it directly beneath the image so it travels with the relevant explanation.
For an actual setup photograph, record which equipment configuration it shows.
Can the image be maintained with the document?
Keep the source asset, editable labels, review notes, and approved export together. Give the illustration a revision identifier and associate it with the document version.
If the procedure changes, include the image in the review. An outdated illustration can continue suggesting the previous setup even after the written instructions have been corrected.
This is a proposed review workflow, with no claimed implementation results. It would be useful to hear how people already handle this in practice.
For those writing technical training material or equipment documentation, where do you draw the boundary between a conceptual illustration and an image that needs engineering approval? Do you review images through the same process as the surrounding instructions?
