spaceboy Posted August 23, 2007 Report Share Posted August 23, 2007 hi, I have a VI which is, at the moment, only a GUI. After initialization all of it is controlled by a single event structure which responds to button pushes. I'd like to add an event which will correspond to data received from a USB modem. I assume this can be done by dynamically registering events, but I have no idea how to start. Any ideas? Maybe dynamically registering events is not even the way to go? thanks, Jon. Quote Link to comment
Eugen Graf Posted August 23, 2007 Report Share Posted August 23, 2007 Take a parallel loop and use Wait On Visa Event VI, to wait (no polling) on USB interrupt. I use this method reading serial interface, there is an event "serial character" to wait on. Eugen Quote Link to comment
LAVA 1.0 Content Posted August 23, 2007 Report Share Posted August 23, 2007 I think that he's looking for some more information on how to use the dynamic event registration also. http://forums.lavag.org/index.php?act=attach&type=post&id=6713 Quote Link to comment
spaceboy Posted August 23, 2007 Author Report Share Posted August 23, 2007 QUOTE(Eugen Graf @ Aug 22 2007, 05:32 PM) Take a parallel loop and use Wait On Visa Event VI, to wait (no polling) on USB interrupt. I use this method reading serial interface, there is an event "serial character" to wait on.Eugen Thanks, that helped. Quote Link to comment
TG Posted September 21, 2007 Report Share Posted September 21, 2007 QUOTE(NormKirchner @ Aug 22 2007, 03:12 PM) I think that he's looking for some more information on how to use the dynamic event registration also. http://lavag.org/old_files/monthly_08_2007/post-208-1187795563.jpg' target="_blank"> Eugen Thats a nice simple example thx for posting it. Hi Norm I am just trying to get the mechanism for (hardware or visa) events ironed out a little more. Could I ask you for a little more detail about what is happening in the example (pic) you posted using the event registration example? PS: I guess serial interrupts would be supported in the same way or no? Could this technique be used to catch incoming characters without constant polling of a serial device? Thank You Quote Link to comment
LAVA 1.0 Content Posted September 21, 2007 Report Share Posted September 21, 2007 QUOTE(TG @ Sep 19 2007, 09:52 PM) Could I ask you for a little more detail about what is happening in the example (pic) you posted using the event registration example? 1. we create a user event that has the data type of the visa event 2. pass that to a register for event node. 3. pass the output of that node to a singe event structure that is registered for that event 4. in the lower loop simply fire off that user defined event every time that you have a VISA event 5.(assumed) in the event structure in the top you would have read the data for the event within that case using the event resource name and event type. Quote Link to comment
