BrokenWire Posted August 23, 2007 Report Share Posted August 23, 2007 Does someone know if you can and if so how you can change a specific channel in a tasks while a VI is running? Quote Link to comment
Ton Plomp Posted August 23, 2007 Report Share Posted August 23, 2007 Yes, but not when the task is running, you will get an error in that case. I don't have DAQmx at my current station, but I suspect you can set the 'channels' property of a DAQmx task. (I assume you use DAQmx) Ton Quote Link to comment
Grampa_of_Oliva_n_Eden Posted August 23, 2007 Report Share Posted August 23, 2007 QUOTE(tcplomp @ Aug 22 2007, 03:15 PM) Yes, but not when the task is running, you will get an error in that case.I don't have DAQmx at my current station, but I suspect you can set the 'channels' property of a DAQmx task. (I assume you use DAQmx) Ton Yes. Provided the task is not running you can you the DAQmx Create Task VI in a loop to add as many channels as you desire. http://forums.lavag.org/index.php?act=attach&type=post&id=6716''>http://forums.lavag.org/index.php?act=attach&type=post&id=6716'>http://forums.lavag.org/index.php?act=attach&type=post&id=6716 Ben Quote Link to comment
orko Posted August 23, 2007 Report Share Posted August 23, 2007 Actually, I think you could use the "Physical Channel Name" property in a DAQmx Channel property node. http://forums.lavag.org/index.php?act=attach&type=post&id=6715 Quote Link to comment
