"Get LV Class Default Value.vi" can't open lvclass within LLB in
When running as an executable (in the run-time engine), "Get LV Class Default Value.vi" produces Error 7 (file not found) when attempting to open an *.lvlib file located inside an LLB file. However, it has no trouble with LLBs when running in the development environment.
I've also seen a similar problem trying to use "Check if File or Folder Exists.vi" (trying to check if a file inside an LLB exists doesn't work when running from a built EXE).
