John Lokanis Posted August 30, 2007 Report Posted August 30, 2007 Has anyone written a VI that will take a simple math formula in a string like: 1+2-3 4+(5*3) 3-(4+5) And return the computed result? I know that NI provides this function in the Eval Formula String.vi in the Gmath library but that is the problem. They put this in a lvlib file. I am trying to build an application with the OpenG builder that includes this function and discovered that the OpenG builder cannot deal with lvlib files properly. Since my application is dependent on the namespace feature of the OpenG builder, my only option is to reinvent this math function myself outside of a lvlib. I have tried to find a way to extract this from the lvlib with no luck. So, can anyone help me not have to reinvent this wheel? Thanks for any help you can offer, -John Quote
Rolf Kalbermatter Posted August 30, 2007 Report Posted August 30, 2007 QUOTE(jlokanis @ Aug 29 2007, 12:43 PM) Has anyone written a VI that will take a simple math formula in a string like:1+2-3 4+(5*3) 3-(4+5) And return the computed result? I know that NI provides this function in the Eval Formula String.vi in the Gmath library but that is the problem. They put this in a lvlib file. I am trying to build an application with the OpenG builder that includes this function and discovered that the OpenG builder cannot deal with lvlib files properly. Since my application is dependent on the namespace feature of the OpenG builder, my only option is to reinvent this math function myself outside of a lvlib. I have tried to find a way to extract this from the lvlib with no luck. Well if you have a LabVIEW version before 8.0 somewhere you can copy the stuff from there. There was no lvlib before 8.0. Alternatingly I wrote long ago a library that works similar to the NI Eval Formula function but is implemented a bit differently dividing the evaluation cleanly into a parser that creates UPN stack intermediate code and an evaluater that operates on that intermediate code. I needed that for speedy calculations where user entered formules would be needed but they didn't change all the time, so parsing the formula once and then evaluating it over and over again had some serious perfomance advantages. The parsing is not trivial but a lot more streamlined than the NI code and the entire thing is also faster. It hasn't been updated for several years but worked fine for what I needed it. LabVIEW 5.0 ExprEval.zip Rolf Kalbermatter Quote
John Lokanis Posted August 30, 2007 Author Report Posted August 30, 2007 Thanks for the code. I hacked together a simple VI to get around this issue for now. It only works on the formula left to right, one works with +, - *, / and will stop when it hits the end o the string or any non number or operator char. see attached. -John Quote
Chris Davis Posted August 31, 2007 Report Posted August 31, 2007 QUOTE(jlokanis @ Aug 29 2007, 12:43 PM) I am trying to build an application with the OpenG builder that includes this function and discovered that the OpenG builder cannot deal with lvlib files properly. Since my application is dependent on the namespace feature of the OpenG builder, my only option is to reinvent this math function myself outside of a lvlib.[/font][/size] I'm using the built in formula parser with the OpenG Builder inside of an LLB with name mangling (adding a prefix specifically) and its working fine. I'm using builder beta 7 in LabView 8.2. I did have trouble with beta 8 when I beta tested it, so I switched back to beta 7. If I remember right, the OpenG Builder beta 7 doesn't actually name mangle files inside a lvlib, but my application was ok with that. Quote
B Chavez Posted August 31, 2007 Report Posted August 31, 2007 Take a look at <LabVIEW dir>\examples\general\strings.llb. There are a two VI's "Parse Postfix Expression" and "Parse Arithmetic Expression", one of the two should do what you want. Quote
Porter Posted December 21, 2017 Report Posted December 21, 2017 Not sure if openG builder and lvlib is still a problem (I don't use openG builder), but I do know that including gmath library increases application builder's executable build time by about 14 minutes (LV2015). On 8/30/2007 at 3:04 PM, John Lokanis said: So, can anyone help me not have to reinvent this wheel? I was about to reinvent as well but then I came across muParser: http://beltoforion.de/article.php?a=muparser LabVIEW API here: Quote
