reentrant:which user pressed button
QUOTE(Mindstormer @ Aug 31 2007, 11:06 AM)
How is it possible to find out at the server side which client pressed a button on a reentrant vi?
thank you
Can we get some more info about this application, the best would be if you could upload the VIs and/or a picture.
It is more or less impossible to answer your question without any more information.
/J
QUOTE(JFM @ Aug 31 2007, 10:59 AM)
/J
Ok, First I will explain what i want to achieve
I have a Reentrant vi and I published it with the web publishing tool. Now different clients can connect to it. To make it simple: on the vi is only a simple button. Now I want to know what the status of the button of every connected user/ip/client is. This information should be available at the server.
I added a reentrant vi with just one button.
thank you
QUOTE(Mindstormer @ Aug 31 2007, 07:58 AM)
thank you
I have not played with this recently...
I believe reeentrant instance have unique references. If you track the references from each instance this may help you.
Another approach is to use templates (VIT) were each instance gets a unique name when opened.
Otherwise you will have to develop you VI's to "drop their own bread crumbs" so you can follow that path back home. :rolleyes:
Is thise the type of info you are after?
Ben
QUOTE(Ben @ Aug 31 2007, 12:24 PM)
Ben
thanks for the reply
The problem is that I searched in labview and on the internet how to get these reference to each instance. But I didnt found it. So you can narrow down my problem to just finding the instance reference from a clone from a reentrant vi. And then I probably can use this reference with vi server to monitor the status of the button.
I never worked with templates so I also will look further how it works
QUOTE(Ben @ Aug 31 2007, 12:58 PM)
I tried this but the property from vi server "this vi" always references to the original vi. So how do I get the reference to the cloned vi's?
QUOTE(Mindstormer @ Aug 31 2007, 10:58 AM)
Before we get into that mess, could you try the template appraoch first?
The behaviour of reentrant VI's has changed with LV 8.X and I am not able to recite the rules off-hand.
Ben
QUOTE(Ben @ Aug 31 2007, 03:06 PM)
Ben
I dont exaclty understand how I should implement the template with the web publishing tool?And does the template need to be reentrant?
QUOTE(Ben @ Aug 31 2007, 03:42 PM)
I don't feel that I am serving you well. :(
In this nugget
http://forums.ni.com/ni/board/message?board.id=170&message.id=226491#M226491' target="_blank">http://forums.ni.com/ni/board/message?boar...=226491#M226491
I posted an example (see post #1) that shows you how to instaciate multiple instaces of a VIT.
Sorry about the lame replies. The Q will take time to answer and doing this while working is just not possible.
Ben
No no I am glad someone is trying to help me. I must leave now, but I will test this after I come back, and that will be monday. I will send u my email, and then you can add me to msn messenger
QUOTE(Mindstormer @ Aug 31 2007, 09:06 AM)
thank you
I too am unqualified to chime in but your problem got me thinking.
Is the server launchin the re-entrant Vi's?
Reason I ask is there may be a way to get at the name of the instance if it is set up as a clone.
Maybe that could be used to get at the status of the button. (With Vi server)
QUOTE(TG @ Sep 2 2007, 03:47 AM)
yes the server has the clones in its memory so I know there must be a way possible. But I only dont know what way.
But maybe I gonna fix my solution with ASP.NET.I read that it cant be coupled to labview code. And I think with ASP it is possible to find out which user pressed a button
  • 3 weeks later...
QUOTE(tcplomp @ Sep 3 2007, 09:53 AM)
That post was what I was looking for I think, Now I did it with ASP. An example of asp code that is steering labview:
Set lvApp = CreateObject("LabVIEW.Application")
lvapp.BringToFront
VIPath = "c:\inetpub\wwwroot\test.vi"
Set VI = lvApp.GetVIReference(VIPath)
VI.FPWinOpen=True%>
<B>OS Name is :</B> <% =lvApp.OSName%><br>
<B>Target CPU is :</B> <% =lvApp.AppTargetCPU%><br>
<B>OS Version is :</B> <% =lvApp.OSVersion%><br>
<B>OS UserName is :</B> <% =lvApp.UserName%><br>
<%Set VI = lvApp.GetVIReference(VIPath)
Call VI.Call(ParamNames, ParamVals)%>
Degree C: <INPUT NAME="degc" SIZE="30" VALUE="<% =ParamVals(0)%>"><P>
Degree F: <INPUT NAME="degf" SIZE="30" VALUE="<% =ParamVals(1)%>"><P>
<INPUT TYPE=SUBMIT VALUE="Return">
<%set vi=nothing%>
