Two Sensors - one stop
berengas
I have a problem with a simple program that I made.
In this program i can only use one daq assist, and I have two sensors. The two sensors have to dected a pencil lead break.
But the problem is that i need two things to append.
First one the program can only stop if the two sensors detect the test.
Second I need to have the values of time of each sensor when the peak is bigger or equal that a value specified by me.
The Program at this moment stops when only the two sensors detect the test, but I have equal times, what is impossible!!!
Anyone know how to fix my problem?
If I not explain very well, please tell me, that i made a more elaborated text.
Best Regards,
Berenguel
What I can see, is that your STOP-function could run before you "Write To Measurement File" node has been executed.
Place the 2 actions in e.g. Flat Sequence structure.
Or as I would do it, through out all Express VIs and create a nice state machine ;)
Cheers,
Mikael
QUOTE(MikaelH @ Sep 26 2007, 10:15 PM)
Thanks for answer to my problem.
My knowledge in labview it's very basic, so the use of Express VIs. This is for a project that I'am making for University, and in my department, the knowledge on this matter is worse than mine.
Best Regards,
Berenguel
