vronto31 Posted October 10, 2007 Report Posted October 10, 2007 Hello I am using PCI 6711 card and generating dual channel analog output frequecy 100Hz to 10 KHz. I generated sine wave amplitute +-2.5 volts by this card and tested it. I was getting correct value but when I connnect termination resisitance of 50 ohms I start seeing clipping after 800mv. Can anone suggest me on why this is happenning. Thanks Vronto Quote
AnalogKid2DigitalMan Posted October 10, 2007 Report Posted October 10, 2007 QUOTE(vronto31 @ Oct 9 2007, 10:50 AM) Hello I am using PCI 6711 card and generating dual channel analog output frequecy 100Hz to 10 KHz. I generated sine wave amplitute +-2.5 volts by this card and tested it. I was getting correct value but when I connnect termination resisitance of 50 ohms I start seeing clipping after 800mv. Can anone suggest me on why this is happenning. Thanks Vronto I'm suprised it held out to 800mV. According to the specs: http://www.ni.com/pdf/manuals/371011c.pdf it can only drive up to +/-5mA. Your 50 ohm load is way to small for the card to drive it (too little resistance). Thus when it cannot supply the current, the voltage will level off. Quote
