Sarfaraz Posted October 11, 2007 Report Posted October 11, 2007 Hi, Does anyone know how to program CIF DP60 a PCMCIA profibus card (manufactured by Hilscher, Germany) using LabVIEW. Is it necessary to know which type of PLC this hardware will connect to, to program it? Well i am making an application in LabVIEW which has to communicate with a PLC using CIF DP60 or DP50 hardware on my pc. Thanks in advance... Any help will be highly appreciated. Quote
i2dx Posted October 12, 2007 Report Posted October 12, 2007 QUOTE(Sarfaraz @ Oct 10 2007, 01:32 PM) Hi,Does anyone know how to program CIF DP60 a PCMCIA profibus card (manufactured by Hilscher, Germany) using LabVIEW. Is it necessary to know which type of PLC this hardware will connect to, to program it? Well i am making an application in LabVIEW which has to communicate with a PLC using CIF DP60 or DP50 hardware on my pc. Thanks in advance... Any help will be highly appreciated. you need: 1. the hardware and the driver for this card installed on your system 2. the hilscher OPC-Server, which should be on the driver CD installed and running 3. then you can create your items with the OPC-Server 4. you can use the datasocket VIs to access the OPC-Items to read and write the items Quote
