"Export simplified image" in executable crashes program
Pick an XY-graph on your front panel. In source code, right-click and select
"Export simplified image". Works Ok. Compile into an executable, and run, richt-click
and select "Export simplified image". Your program wil crash. Confirmed by NI locally.
(Haven't tested the other charts and graphs, but I suspect you'll see the same thing.)
Martin
That's interesting, I guess that gives me a good reason to hold off on migrating to 8.5 a little while. Did they give any workarounds? I have a exe written in 8.2.1 with an XY graph that works fine, so it seems like it's probably a 8.5 only bug.
