Vision Assistant "create labview VI from script" Help
I saw some topics related to this problem , but none helped me.
I'm using vision assistant (7.1.1) and want to create a Vi from my script, but I always received an error message "Lavbiew and Imaq vision not found". I have Labview 8.2 in windows vista. can anyone help me solve this problem, in fact I reinstall the vision development but I still receive the error.
Thank you in advance for your help.
QUOTE(daro @ Oct 25 2007, 08:00 PM)
What is the order you installed your software?
You should install LV first, then the Vision stuff. If you are using Vision 7.1.1, then you need a number of components from different cd's installed. As far as I remember,
IMAQ Vision, IMAQ for 1394 etc. etc.. its been a while since I used 7.1.1 but the newer versions of Vision have everything integrated into a couple of CD's instead of a million separate components.
Also, have you activated your Vision package? Maybe it is not allowing you to generate VI's because of that.
Another thing: check that LV8 is indeed compatible with Vision 7.1.1 (I think it should be, but check on the NI website or the LV 8 release notes).
Neville.
QUOTE(Neville D @ Oct 26 2007, 09:21 AM)
Neville.
Thanks for your response.
I first installed LV, then Vision, anyway I've delete all vision stuff and reinstalled.
Yes, the vision is activated.
I'll check the compatibility, thank you.
QUOTE(daro @ Oct 27 2007, 09:10 AM)
I really doubt that Vision Assistent 7.1 can control LabVIEW 8.2 to create VIs in it. The other way around I think would work but not a random number of versions backwards.
Rolf Kalbermatter
