bimbim Posted November 14, 2007 Report Posted November 14, 2007 Hi All, I am currently trying to use an Intensity HDMI board from Black Magic. The main problem I have is that I can't retrieve my capture when I am using 720p setting. I can get my picture (in a LabVIEW image ctl) when my video source and my board are set to 576i (PAL). My driver displays an ActiveMovie window but my image control in LabVIEW is not refreshed and remains black. Does someone experimented such issue with hudge video format (HD)? Is there other (free if possible) DirectShow VIs available? Is there a setting to apply to the image control in LabVIEW? Thank you in advance for your help. I am looking forward to your answer. Best regards Bim Quote
bmoyer Posted May 7, 2014 Report Posted May 7, 2014 Did you ever figure out a solution to this? I'm also trying to acquire HDMI video into LabVIEW but can't get it working. Thanks, Bruce Quote
bimbim Posted February 8, 2017 Author Report Posted February 8, 2017 Hi, I'm now using http://forums.ni.com/t5/Community-Documents/DirectShow-NET-LabVIEW-SDK-Video-Audio-IP-streams/ta-p/3493927 Works fine Bim Quote
