rkapoor Posted November 26, 2007 Report Posted November 26, 2007 I am using Call Library function and Adapt to type with LV8.2. How can I define dynamic arrays in LabVIEW? Regards, Rachana Quote
Ton Plomp Posted November 27, 2007 Report Posted November 27, 2007 QUOTE(rkapoor @ Nov 26 2007, 01:40 AM) I am using Call Library function and Adapt to type with LV8.2. How can I define dynamic arrays in LabVIEW?Regards, Rachana What is a dynamic array exactly? Ton Quote
PaulG. Posted November 27, 2007 Report Posted November 27, 2007 Use the Reshape Array primitive. You can use the Build Array or Initialize Array an n-dimension array in the beginning of your code then reshape it as needed. Quote
