0815Jack Posted November 30, 2007 Report Posted November 30, 2007 hi, i want to use the Mediainfo DLL ( http://mediainfo.sourceforge.net/en / http://mediainfo.sourceforge.net/en/Support/SDK/Quick_Start ) to get some infos from video files (duration, resolution, codec etc). i know that i have to use the knot for external libraries, but i dont know how to start, cause i never worked before with external calls. has anybody got a hint or example for me? Quote
Rolf Kalbermatter Posted November 30, 2007 Report Posted November 30, 2007 QUOTE(0815Jack @ Nov 29 2007, 05:41 AM) hi,i want to use the Mediainfo DLL ( http://mediainfo.sourceforge.net/en / http://mediainfo.sourceforge.net/en/Support/SDK/Quick_Start ) to get some infos from video files (duration, resolution, codec etc). i know that i have to use the knot for external libraries, but i dont know how to start, cause i never worked before with external calls. has anybody got a hint or example for me? Do you know anything about C programming? If so you should be set fairly well and reading a bit in the External Code Reference Manual in the LabVIEW online help should get you enough to get started. Without at least some basic C programming knowledge you will be in for a good and most possibly steep learning experience before it does not crash anymore. And I just see that they export a C++ API. The Call Library Node can not call that directly. It can only access standard C exported functions, no C++ object interfaces. So you will have to create a wrapper DLL, wrapping the C++ method calls into standard C exported functions. All in all it does not seem to me to be a good project to start into the depths of the Call Library Node and C programming. Possibly the ActiveX wrapper or maybe the Visual Basic 5 and 6 example could help a bit. The ActiveX wrapper would allow you to access the Media Library through LabVIEWs ActiveX interface which would mean you do not have to directly deal with C datatypes, memory allocation issues and all such difficulties. Rolf Kalbermatter Quote
Eugen Graf Posted November 30, 2007 Report Posted November 30, 2007 At first read this PDF: http://www.labviewtutorial.de/downloads/UsingExtCode.pdf Eugen Quote
0815Jack Posted November 30, 2007 Author Report Posted November 30, 2007 thx for your answers.... it looks like that this is more complicate than i thought ...but i will have a closer look to the pdf and active X is there a easier way to get the video spec? Quote
