silver Posted December 14, 2007 Report Posted December 14, 2007 Dear Friends, My code is so far working, but I have the following task to accomplish. I am converting hexadecimals to Decimals (x,yz) values and plot them. The sampling rate(0,1 = 10 values per second) and the offset of the chart are given through the property node of the Chart. I also convert the time stamp to Excel format ( e.g 36000,5 = 36000 days after the date 01.01.1900 and after the comma is the time 0,5 = 12:00:00 AM) So now , I want to save the values in an Excel sheet with its time stamp. How can I solve this problem? pls see my code to get my points. Quote
LAVA 1.0 Content Posted December 14, 2007 Report Posted December 14, 2007 The reference time for LabVIEW is 12:00 a.m., Friday, January 1, 1904, Universal Time. So you have 1462 day offset. For excel you have the correct reference time but don't forget that it's not in UTC format. Eric Quote
TobyD Posted December 14, 2007 Report Posted December 14, 2007 QUOTE(silver @ Dec 12 2007, 09:40 PM) Quote Dear Friends,My code is so far working, but I have the following task to accomplish. I am converting hexadecimals to Decimals (x,yz) values and plot them. The sampling rate(0,1 = 10 values per second) and the offset of the chart are given through the property node of the Chart. I also convert the time stamp to Excel format ( e.g 36000,5 = 36000 days after the date 01.01.1900 and after the comma is the time 0,5 = 12:00:00 AM) So now , I want to save the values in an Excel sheet with its time stamp. How can I solve this problem? pls see my code to get my points. You're almost there. You can use the Write to Spreadsheet File.vi in the File I/O pallete to write your data to a .csv file. Check the help file and examples to see how this vi works. Quote
