Saving array elents and time stamp in Excel sheet
Dear Friends,
My code is so far working, but I have the following task to accomplish.
I am converting hexadecimals to Decimals (x,yz) values and plot them. The sampling rate(0,1 = 10 values per second) and the offset of the chart are given through the property node of the Chart.
I also convert the time stamp to Excel format ( e.g 36000,5 = 36000 days after the date 01.01.1900 and after the comma is the time 0,5 = 12:00:00 AM)
So now , I want to save the values in an Excel sheet with its time stamp.
How can I solve this problem?
pls see my code to get my points.
QUOTE(silver @ Dec 12 2007, 09:40 PM)
Dear Friends,
You're almost there. You can use the Write to Spreadsheet File.vi in the File I/O pallete to write your data to a .csv file. Check the help file and examples to see how this vi works.
