Horizontal lines appear in grab acquision after a while
Hello everyone,
My system is using 4 cameras. this system worked for about 3 years and never had a problem with this. But now, When I start my process for less than an hour, I start to see horizontal lines in my acquisition image. Even when I close all my VI, this also happen in MAX. For the Xmas holiday's, I've turn all the system off. When I started everything back, My PXI chassis wasn't in MAX. So I've finally figured out that I had to open the PXI chassis before opening the computer. But, by doing that, I've lost some seting that I've manage to recover from backups. Is there a seting in MAX that could do this? A seting that could have a link with the image buffer? I'm also getting errors about the IMAQ acquisition that I never had before like "IMG_ERR_TIM0" Thank you for your help.
I'm using a PXI-1000B chassis with a PXI-1409 acquisition card. I'm using Labview 6.1
Thank you for your help,
I have no advice, only consolation.
I had two PCI-1409 boards in a computer with 8 cameras. All 8 are wired into one custom power supply box that should supply enough current for all 8.
At some point I started getting similar problems. "Unrecognizable video source" or some such message from my software and MAX. After a few days of testing station "warm-up" time, I figured out that I needed to turn on the power supply at least 15 minutes before trying to acquire an image.
... about midway though the life of this equipment, I did upgrade the IMAQ software.. I don't think that had anything to do with it though..
I had no problem with a 30 minute warm-up period, so a label on the power supply stated this requirement.
Like I said.. no advice.. only consolation.
Good luck,
James
QUOTE(coolaid @ Jan 9 2008, 04:52 AM)
Hello everyone,
It sounds to me like it could be heat related. Video cameras and processing equipment will often start outputting weird artifacts when it gets to hot. I would make sure all fans are still turning smoothly and give everything a good cleaning with compressed air. You could even setup some fans blowing air directly on the equipment and run it for a while to see if it helps.
Good Luck,
Toby
QUOTE(TobyD @ Jan 9 2008, 11:48 AM)
Good Luck,
Toby
Good idea, I will try to clean it.  The problem that I also have is that I didn't have any problem with it and it's running for about 3 years from now.  The problem is temporary solve when I restart the computer.  I didn't change any hardware or software before thi problem occur.
thank you for your support.
