zappa2 Posted January 24, 2008 Report Posted January 24, 2008 Hi, I am almost finishing my project, but I still have a question. I designed 4 special big (4x 8 cm) buttons with and image on them. These are normal Boolean buttons. At this point multiple buttons can be enabled at the same time, but my requirement is that only one button can be enabled at the same time. When pressing one, the other enabled button should turn off. How to do this? Normally you should use radio buttons I guess, but my buttons have a special design. thnx Quote
Ton Plomp Posted January 24, 2008 Report Posted January 24, 2008 QUOTE(zappa2 @ Jan 23 2008, 10:23 AM) ...I designed 4 special big (4x 8 cm) buttons with and image on them. [plug] You could have used the Boolean XControl [/plug] QUOTE When pressing one, the other enabled button should turn off. How to do this? Normally you should use radio buttons I guess, but my buttons have a special design. You can change every button of a radio button (right click on border, select advanced, customize) Ton Quote
zappa2 Posted January 24, 2008 Author Report Posted January 24, 2008 QUOTE(tcplomp @ Jan 23 2008, 01:00 PM) [plug]You could have used the Boolean XControl [/plug] You can change every button of a radio button (right click on border, select advanced, customize) Ton Thank you, the radio buttons were the solution. Quote
