bayram_mercan Posted January 25, 2008 Report Posted January 25, 2008 i'm getting thermocouple data from a NI board. but also i want to get exact time like hh:mm:ss and also miliseconds. because i get 100 samples per second. how can i do that? also why my task gets last 100 data? Quote
Tim_S Posted January 26, 2008 Report Posted January 26, 2008 QUOTE(bayram_mercan @ Jan 24 2008, 05:57 PM) i'm getting thermocouple data from a NI board. but also i want to get exact time like hh:mm:ss and also miliseconds. because i get 100 samples per second. how can i do that? also why my task gets last 100 data? You're getting 100 samples back because that's how many you've configured the DAQ assistant to return. I suspect that 100 samples is the default and it wasn't changed. I'm not sure what you're looking to do with getting the exact time. Are you looking to have a timestamp for every sample? For the start of the data? For the end of the data? Quote
bayram_mercan Posted January 26, 2008 Author Report Posted January 26, 2008 i mean if i take signal for 5 seconds, i want to get 500 values. but i get last 100 sample values. for the time, i wnt to get the exact time for each sample value. Quote
Tim_S Posted January 27, 2008 Report Posted January 27, 2008 QUOTE(bayram_mercan @ Jan 25 2008, 07:31 AM) i mean if i take signal for 5 seconds, i want to get 500 values. but i get last 100 sample values.for the time, i wnt to get the exact time for each sample value. Converting the dynamic data type to a waveform will provide you t0 and dt. From there you can get the array you're looking for. Quote
bayram_mercan Posted January 29, 2008 Author Report Posted January 29, 2008 QUOTE(Tim_S @ Jan 26 2008, 05:44 PM) Converting the dynamic data type to a waveform will provide you t0 and dt. From there you can get the array you're looking for. thank you for the help. Quote
