sara Posted February 4, 2008 Report Posted February 4, 2008 hi all i do this example in labview to write the value of input to access but i have error can any one help me to solve this error http://www.fileflyer.com/view/qM8LeAv Quote
Justin Goeres Posted February 4, 2008 Report Posted February 4, 2008 QUOTE(sara @ Feb 3 2008, 12:37 PM) Quote can any one help me to solve this error What's the error code, and what does the source text say? Quote
alukindo Posted February 5, 2008 Report Posted February 5, 2008 Your code shows that your column names include spaces, this makes SQL code prone to errors. For table names, you should use underscores symbol ( _ ) instead of spaces and then try again. This assumes that you were able to succesfully connect to your ACCESS Database Anthony Quote
Rolf Kalbermatter Posted February 5, 2008 Report Posted February 5, 2008 QUOTE(alukindo @ Feb 4 2008, 01:09 AM) Quote Your code shows that your column names include spaces, this makes SQL code prone to errors. For table names, you should use underscores symbol ( _ ) instead of spaces and then try again.This assumes that you were able to succesfully connect to your ACCESS Database Anthony Or you can usually put the column identifiers into square brackets to allow the SQL parser to recognize them as one entity. But not using spaces in column names is actually good practice. Rolf Kalbermatter Quote
sara Posted February 5, 2008 Author Report Posted February 5, 2008 thanks alot for your reply and help ... i take your device and program run well thanks alot :thumbup: Quote
