Bhima Posted February 6, 2008 Report Share Posted February 6, 2008 I’ve inherited a large cumbersome Labview application, with scores of SubVIs. The directory structure of this application is a disaster, with multiple, probably unused, copies of the SubVIs scattered around in various sub-directories. I would like to construct a list of the SubVIs which are really used and their full path. Then I would like to construct a new directory tree, move the actually used SubVIs into rational places, and finally change the path references that the main VI uses for those SubVIs. Also I am trying to move this application from 7.1 to 8.5 and I’m having trouble making an executable for reasons I think are related to confusing which SubVIs are being used. What is the most sensible way to do this? Quote Link to comment
mross Posted February 6, 2008 Report Share Posted February 6, 2008 Bhima, You may first wish to create a backup of the current file system, if that does not already exist. There may be better ways to do this, but I think all you need is to save it in 8.5 and save all suv-VIs to raise it up. To clean it up: Open the top level VI. File/Save As Duplicate Hierarchy Give it a new location GO Since you don't like the reproduced Hierarchy you can now move the new file set around as you desire. You can call up the top level VI and manually direct it to the new locations. Use View/VI Hierarchy as an aid if you like. If you want new names for the old sub-VIs there is no simple way to do this. You just have to rename and make the top level VI call them all up. VI Hierarchy is a good help for this sort of thing. Mike Quote Link to comment
Bhima Posted February 6, 2008 Author Report Share Posted February 6, 2008 Thanks Mike, this worked the way you said it would. This app was made in 7.1 and I'm new to Labview, so I haven't spent much time in Labview 8.5. Now I wish I had... I don't think 7.1 works this way. Now if I could only convince 8.5 to make a Windows excutable as easily as 7.1 Quote Link to comment
Neville D Posted February 6, 2008 Report Share Posted February 6, 2008 QUOTE(Bhima @ Feb 5 2008, 03:59 AM) Thanks Mike, this worked the way you said it would. This app was made in 7.1 and I'm new to Labview, so I haven't spent much time in Labview 8.5. Now I wish I had... I don't think 7.1 works this way. Now if I could only convince 8.5 to make a Windows excutable as easily as 7.1 In 8.x there are two separate steps to creating an executable. Building the Installer (which also gives you the option of including DAQmx settings, NI-MAX, LV-Runtime Engine etc. etc) Building the Exe This way you can repeatedly build the exe quickly instead of building the installer as well (like before). I would suggest start with a fresh build spec instead of trying to use the old 7.x one. Sometimes the old one gets corrupted, and at any rate, its pretty straightforward to just build an exe. Define the top level VI (include any dynamic VI's) direct where you want the result stored, the name of the exe and then build. Neville. Quote Link to comment
Omar Mussa Posted February 6, 2008 Report Share Posted February 6, 2008 QUOTE(mross @ Feb 5 2008, 03:27 AM) Open the top level VI.File/Save As Duplicate Hierarchy Give it a new location GO This method has a terrible flaw. If any VIs are being called dynamically, you will not find them using this method. To check if any VIs are being loaded dynamically look for any instances in your application of the 'Open VI Reference' primative (member of the 'Application Control' pallette). Quote Link to comment
