frentzen Posted February 8, 2008 Report Posted February 8, 2008 Hi, is there a way, to convert a string into a timestamp? The string contains dd.mm.yyyy hh:mm:ss Thanks for any help, Thomas Quote
ned Posted February 8, 2008 Report Posted February 8, 2008 Yes. Take a look at the "Scan from String" primitive in the String pallette, and read the help for Format Specifiers, specifically %T which is used to format time. Quote
Ton Plomp Posted February 8, 2008 Report Posted February 8, 2008 QUOTE(frentzen @ Feb 7 2008, 03:03 PM) Quote Hi,is there a way, to convert a string into a timestamp? The string contains dd.mm.yyyy hh:mm:ss Thanks for any help, Thomas A suggestion is given http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=299002#M299002' target="_blank">here (dark side warning) It contains almost your string formatter: just remove the %3u Ton Quote
frentzen Posted February 13, 2008 Author Report Posted February 13, 2008 ZITAT(tcplomp @ Feb 7 2008, 05:37 PM) Quote A suggestion is given http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=299002#M299002' target="_blank">here (dark side warning)It contains almost your string formatter: just remove the %3u Ton Hi Ton, thanks for your support. That really helps! Thomas Quote
