Morten Pedersen Posted February 9, 2008 Report Posted February 9, 2008 Hi, We are a company that develops test and measurement systems, with LabVIEW and TestStand. We are working in the latest and prior versions of the development systems. We have in mind to change our existing source code control (SCC) to the following toolchain in the latest versions: - Tigris Subversion Server on Linux (Tigris SVN) - TortoiseSVN Client (to use SVN via file explore) - PushOK SVN Client (to use SVN from the LV project explore) Does anyone have some Pros. and/or Cons. Regarding this setup for company use with LabVIEW and TestStand? Best regards, Morten Pedersen Quote
Ton Plomp Posted February 9, 2008 Report Posted February 9, 2008 QUOTE(Morten Pedersen @ Feb 8 2008, 11:24 AM) Quote Hi,We are a company that develops test and measurement systems, with LabVIEW and TestStand. We are working in the latest and prior versions of the development systems. We have in mind to change our existing source code control (SCC) to the following toolchain in the latest versions: - Tigris Subversion Server on Linux (Tigris SVN) - TortoiseSVN Client (to use SVN via file explore) - PushOK SVN Client (to use SVN from the LV project explore) Regarding this setup for company use with LabVIEW and TestStand? I have a similar setup running, where the server is on a Linux Apache box, and I use a Subversion WIndows client for LabVIEW 6.x and 7.x and advanced techniques. For LabVIEW 8.x I use the PushOK Client. Both work OK, but you should notice that anonymouse browsing should be disallowed to have the PushOK function correctly. Be aware that if you want to build your own tool in LabVIEW 8.x with the built-in SCC api, the PushOK client gives pop-ups. Ton Quote
Justin Goeres Posted February 9, 2008 Report Posted February 9, 2008 QUOTE(Morten Pedersen @ Feb 8 2008, 03:24 AM) Quote - Tigris Subversion Server on Linux (Tigris SVN)- TortoiseSVN Client (to use SVN via file explore) That's my setup (everything but PushOK), and I've been very happy with it. No problems at all. Quote
