Acquiring a hi-speed square wave
Hello everyone,
I am acquiring a digital signal from a rotating shaft encoder. The square wave comes at a rate of 36,000 pps, at almost constant intervals. What sampling rules does this application follow. Shall I go after the Niquist Criterion, or a 36kS/s is enough to catch all the signals.
Thankyou very much for your help.
QUOTE(fuzzycontrolfreak @ Feb 25 2008, 08:35 AM)
Hello everyone,
That depends. What data are you trying to extract from your signal?
Hello everyone,
If you know you're getting a 36 kHz signal and you want shape data, then you should be sampling at ten-times the expected maximum frequency (twice for frequency). The sugestion of the encoder is good if you want to be synchronous to the shaft (data collected in constant degrees apart rather than time). What you intend to do with the data after you've collected determines which method would be best.
Tim
