george seifert Posted March 27, 2008 Report Posted March 27, 2008 I'm sending data to a graph that could have a different number of plots depending on the user settings. I'm trying to get the plot legend to only show the number of plots that are present. I have the scrollbar turned on on the legend because the number of plots could be larger than will fit in the legend display. The number of rows in the legend doesn't change with the number of plots. How can I get the number of rows in the legend to match the number of plots? I've attached a VI that has the data and plot for an example. Thanks, George Download File:post-2786-1206556679.vi Quote
PaulL Posted March 27, 2008 Report Posted March 27, 2008 George, Maybe I am missing something, but your example seems to me to do what you describe to be the desired behavior. If I delete an element of the data array, the number of rows in the legend decreases by one when I run the VI.... Isn't that what you want (good!) or do you need something else? Paul Quote
LAVA 1.0 Content Posted March 27, 2008 Report Posted March 27, 2008 QUOTE (Paul_at_Lowell @ Mar 26 2008, 02:06 PM) George,Maybe I am missing something, but your example seems to me to do what you describe to be the desired behavior. If I delete an element of the data array, the number of rows in the legend decreases by one when I run the VI.... Isn't that what you want (good!) or do you need something else? Paul George, Is Property >>> Legend >>> Plots shown What you are looking for? Paul, Is Property >>> Autosize Legend True? Ben Quote
PaulL Posted March 27, 2008 Report Posted March 27, 2008 QUOTE (neB @ Mar 26 2008, 12:16 PM) Paul,Is Property >>> Autosize Legend True? Ben Not with a property nodes. Right-clicking on the graph and checking or unchecking Auto Size Plot Legend doesn't change the behavior for this particular example. Paul Quote
LAVA 1.0 Content Posted March 27, 2008 Report Posted March 27, 2008 QUOTE (Paul_at_Lowell @ Mar 26 2008, 02:42 PM) Not with a property nodes. Right-clicking on the graph and checking or unchecking Auto Size Plot Legend doesn't change the behavior for this particular example.Paul I should have mentioned that property was from LV 7.1. They re-arranged a lot of the legend and cursor stuff in LV 8+. My Bad. Ben Quote
george seifert Posted March 27, 2008 Author Report Posted March 27, 2008 QUOTE (Paul_at_Lowell @ Mar 26 2008, 02:06 PM) George,Maybe I am missing something, but your example seems to me to do what you describe to be the desired behavior. If I delete an element of the data array, the number of rows in the legend decreases by one when I run the VI.... Isn't that what you want (good!) or do you need something else? Paul Well that's part of what I want. If you scroll down the plot legend you'll see that there are extra entries there.The problem is that I need the scrollbar there for those cases where there are more plots than will fit on a screen sized plot legend (29 entries in my case). If I only had a max of 29 possible curves, then I could limit the number of rows and do away with the scroolbar and everything would be hunky-dory. On the other hand - practically speaking - trying to figure out which curve is which when there are more than 29 is pretty difficult. But it still bugs me that the number of legend entries is too big. George Quote
PaulL Posted March 27, 2008 Report Posted March 27, 2008 QUOTE (george seifert @ Mar 26 2008, 01:09 PM) Well that's part of what I want. If you scroll down the plot legend you'll see that there are extra entries there.The problem is that I need the scrollbar there for those cases where there are more plots than will fit on a screen sized plot legend (29 entries in my case). If I only had a max of 29 possible curves, then I could limit the number of rows and do away with the scroolbar and everything would be hunky-dory.On the other hand - practically speaking - trying to figure out which curve is which when there are more than 29 is pretty difficult. But it still bugs me that the number of legend entries is too big. George OK, I see the problem now. Yes, I would want different behavior, too. I don't know of a solution. Quote
lvb Posted May 13, 2008 Report Posted May 13, 2008 This seems like a bug to me. When showing the scrollbar of the Waveform Graph, the maximum number of plots created (ever) is displayed. Quote
