10 Turn Pot Knob Control
lvb
I am creating an application that is simulating a 10-turn pot. I figured that I would probe the community to find out if this exists anywhere and for advice on how to implement this control.
So far I have found a resource here, but it limits user input to the increment/decrement buttons (does not allow the user to rotate the wheel).
The one roadblock I see in creating a control would be detecting if the wheel rotation direction. For instance: Given a 360 degrees of rotation, has rotated in the clockwise or counter-clockwise direction when transitioning between values (to account for roll-over).
Any info would be appreciated!
Thanks
QUOTE (brianafischer @ Apr 4 2008, 09:22 AM)
Hiya,
To get you started, here is a "standard" 360-counter device.
http://lavag.org/old_files/post-3343-1207331297.vi'>Download File:post-3343-1207331297.vi
It basically counts up and down as the user rotates the knob (the knob having a range from 0 to 360 -- you should be able to adjust this to any resolution). I leave it to your devices for figuring out how to get it to stop (Hint: One option would be to implement this in an X-Control).
have a nice day,
--H
