Strange behaviour of VI Express Write LVM
CITATION(tcplomp @ Apr 11 2008, 02:41 PM)
You should change this to 'Append to file'
Thanks... but I know this ;-(
The problem is for example with time column... why 0 ?
It should increase by 50ms step... but it doesn't !
I guess that the .lvm file is open for writting each time
the measure is put in the file
the lvm file is closed
next point
the lvm file is open (again) for writing ...
It seams that each time the file is open for writing, time is set to zero
That's why I found it very strange !
CITATION(tcplomp @ Apr 11 2008, 03:43 PM)
I select "append"
X columns : only one
I get
LabVIEW Measurement
Writer_Version 0.92
Reader_Version 1
Separator Tab
Multi_Headings Yes
X_Columns One
Time_Pref Absolute
Operator scls
Date 2008/04/11
Time 16:10:58,639664
***End_of_Header***
Channels 2
Samples 1 1
Date 2008/04/11 2008/04/11
Time 16:10:58,641664 16:10:58,641664
X_Dimension Time Time
X0 0.0000000000000000E+0 0.0000000000000000E+0
Delta_X 1.000000 1.000000
***End_of_Header***
X_Value Untitled Untitled 1 Comment
0.000000 0.000000 20.000000
0.000000 10.000000 20.000000
0.000000 10.000000 25.000000
0.000000 20.000000 25.000000
0.000000 20.000000 30.000000
0.000000 30.000000 30.000000
0.000000 30.000000 35.000000
0.000000 40.000000 35.000000
0.000000 40.000000 40.000000
0.000000 50.000000 40.000000
0.000000 50.000000 45.000000
0.000000 60.000000 45.000000
0.000000 60.000000 50.000000
0.000000 70.000000 50.000000
0.000000 70.000000 55.000000
0.000000 80.000000 55.000000
0.000000 80.000000 60.000000
0.000000 90.000000 60.000000
0.000000 90.000000 65.000000
0.000000 100.000000 65.000000
0.000000 100.000000 70.000000
0.000000 110.000000 70.000000
0.000000 110.000000 75.000000
0.000000 120.000000 75.000000
0.000000 120.000000 80.000000
0.000000 130.000000 80.000000
0.000000 130.000000 85.000000
0.000000 140.000000 85.000000
0.000000 140.000000 90.000000
0.000000 150.000000 90.000000
0.000000 150.000000 95.000000
0.000000 160.000000 95.000000
0.000000 160.000000 100.000000
0.000000 170.000000 100.000000
I don't like what the first column ! (it doesn't means that I want to erase it
It means that the value should increase from 50ms)
You can also notice that "Samples" contain 1 1
but this is not the number of samples !!!!
So when I need to read this LVM file (into for example VI Express Generate Abitrary signal... it fails
... in fact it imports only one line !!!)
I also tryed to put this code inside a loop...
http://lavag.org/old_files/post-11213-1207924771.vi'>Download File:post-11213-1207924771.vi
but the problem is same !
Look at the first column you will see that time is always equal to 0.
This is not the standard behaviour of this VI Express.
I ever use it... and time was increasing (in this column)
See
LabVIEW Measurement
Writer_Version 0.92
Reader_Version 1
Separator Tab
Multi_Headings Yes
X_Columns Multi
Time_Pref Absolute
Operator scls
Date 2008/04/11
Time 19:41:37,412999
***End_of_Header***
Channels 2
Samples 1 1
Time 19:41:37,414999 19:41:37,414999
***End_of_Header***
X_Value Untitled X_Value Untitled 1 Comment
0.000000 0.000000 0.000000 20.000000
0.000000 10.000000 0.000000 20.000000
0.000000 10.000000 0.000000 25.000000
0.000000 20.000000 0.000000 25.000000
0.000000 20.000000 0.000000 30.000000
0.000000 30.000000 0.000000 30.000000
0.000000 30.000000 0.000000 35.000000
0.000000 40.000000 0.000000 35.000000
0.000000 40.000000 0.000000 40.000000
0.000000 50.000000 0.000000 40.000000
0.000000 50.000000 0.000000 45.000000
0.000000 60.000000 0.000000 45.000000
0.000000 60.000000 0.000000 50.000000
0.000000 70.000000 0.000000 50.000000
0.000000 70.000000 0.000000 55.000000
0.000000 80.000000 0.000000 55.000000
0.000000 80.000000 0.000000 60.000000
0.000000 90.000000 0.000000 60.000000
0.000000 90.000000 0.000000 65.000000
0.000000 100.000000 0.000000 65.000000
0.000000 100.000000 0.000000 70.000000
0.000000 110.000000 0.000000 70.000000
0.000000 110.000000 0.000000 75.000000
0.000000 120.000000 0.000000 75.000000
0.000000 120.000000 0.000000 80.000000
0.000000 130.000000 0.000000 80.000000
0.000000 130.000000 0.000000 85.000000
0.000000 140.000000 0.000000 85.000000
0.000000 140.000000 0.000000 90.000000
0.000000 150.000000 0.000000 90.000000
0.000000 150.000000 0.000000 95.000000
0.000000 160.000000 0.000000 95.000000
0.000000 160.000000 0.000000 100.000000
0.000000 170.000000 0.000000 100.000000
0.000000 170.000000 0.000000 105.000000
0.000000 180.000000 0.000000 105.000000
QUOTE (scls19fr @ Apr 11 2008, 10:32 AM)
Ahhh, I understand what you are saying now...
You currently have reset set to true on the "Write to meaurement file" express VI. Set that to false (or remove it because the default is false) and it should work for you. By setting reset to true you are resetting the timesamp back to 0 each time.
The problem is same !
Download File:post-11213-1207943541.vi
I send on activate pin the constant "true"
I send on reinitialize pin the constant "false"
LabVIEW Measurement
Writer_Version 0.92
Reader_Version 1
Separator Tab
Multi_Headings Yes
X_Columns Multi
Time_Pref Absolute
Operator scls
Date 2008/04/11
Time 21:49:53,620999
***End_of_Header***
Channels 2
Samples 1 1
Time 21:49:55,382999 21:49:55,382999
***End_of_Header***
All right ! it works better for generating the lvm file.
I can change to "Erase file" (instead of append to file) and as you can see I get all values !
Time is well increasing !
But there is still a problem with sample number...
It is always equal to 1 for each channel....
So when I use the VI Express / Input / Generate an arbitrary signal and I want to import
the generated signal... only one point (the first one) is imported...
I can manualy fix it by changing samples number but that's a (very) dirty hack !
LabVIEW Measurement
Writer_Version 0.92
Reader_Version 1
Separator Tab
Multi_Headings No
X_Columns One
Time_Pref Absolute
Operator scls
Date 2008/04/12
Time 10:16:24,330057
***End_of_Header***
Channels 2
Samples 1 1
Date 2008/04/12 2008/04/12
Time 10:16:24,331058 10:16:24,331058
***End_of_Header***
0.041000 10.000000 20.000000
0.141000 10.000000 25.000000
0.241000 20.000000 25.000000
0.341000 20.000000 30.000000
0.441000 30.000000 30.000000
0.541000 30.000000 35.000000
0.641000 40.000000 35.000000
0.741000 40.000000 40.000000
0.841000 50.000000 40.000000
0.941000 50.000000 45.000000
1.041000 60.000000 45.000000
1.216000 60.000000 50.000000
1.241000 70.000000 50.000000
1.341000 70.000000 55.000000
1.441000 80.000000 55.000000
1.541000 80.000000 60.000000
1.641000 90.000000 60.000000
1.741000 90.000000 65.000000
1.841000 100.000000 65.000000
1.941000 100.000000 70.000000
2.041000 110.000000 70.000000
2.141000 110.000000 75.000000
2.241000 120.000000 75.000000
2.341000 120.000000 80.000000
2.441000 130.000000 80.000000
2.541000 130.000000 85.000000
2.641000 140.000000 85.000000
2.741000 140.000000 90.000000
2.841000 150.000000 90.000000
2.941000 150.000000 95.000000
3.041000 160.000000 95.000000
3.141000 160.000000 100.000000
3.241000 170.000000 100.000000
Download File:post-11213-1207988553.vi
About the problem with my VI Express "Write To Measurement File"
it was probably because I was loking inside the VI Express (using contextual menu Open Front)
but I don't save it... I just Undo... to get again the VI Express (instead of a sub vi)
So it shouldn't break anything... but it break it ;-(
See also
http://forums.ni.com/ni/board/message?boar...hread.id=315785
Solution is here :
CITATION
you can place place the Write to Measurement File outside your loop and do a single write. Wire the data through the while loop and on the exit tunnel, select Enable Indexing. This will create an array of values. Now, when you use the Write to Measurement File, your number of samples will be correct and you will have a single segment that can be read by the Generate Arbitrary Signal function
Download File:post-11213-1208026347.vi
