Micael Posted April 25, 2008 Report Posted April 25, 2008 Hi all, I'm new to LAVA, and I am looking for a way to search shared variable nodes inside the VIs block diagrams, just the way you can search for all instances of a subVI by right-clicking on it or using Ctrl-F. For instance I downloaded The "scripting tools" library, and it seems that it could be useful. I someone has already done something similar, or has any suggestions, they will be welcome. Thanks in advance (and sorry for my english). Micaël. Quote
LAVA 1.0 Content Posted April 25, 2008 Report Posted April 25, 2008 QUOTE (Micael @ Apr 24 2008, 07:54 AM) Hi all,I'm new to LAVA, and I am looking for a way to search shared variable nodes inside the VIs block diagrams, just the way you can search for all instances of a subVI by right-clicking on it or using Ctrl-F. For instance I downloaded The "scripting tools" library, and it seems that it could be useful. I someone has already done something similar, or has any suggestions, they will be welcome. Thanks in advance (and sorry for my english). Micaël. If you do a search Objects >>> Structures >>> Shared vaiables you will get list of ALL of the shared variables. I have not heard of any way to search for a specific shared variable. A number of the LabVIEW Champions have fed-back that this situation should be addressed. Ben Quote
Micael Posted April 26, 2008 Author Report Posted April 26, 2008 QUOTE (neB @ Apr 24 2008, 02:09 PM) If you do a search Objects >>> Structures >>> Shared vaiablesyou will get list of ALL of the shared variables. I have not heard of any way to search for a specific shared variable. A number of the LabVIEW Champions have fed-back that this situation should be addressed. Ben Thanks for your help. I managed to do a search for a specific variable using its connector name. The problem is that I used the property node "App:All VIs in memory" to list the vis to search in, so I need to put the search VI inside the project where I want to find the variables. Do you know a way to list all VIs in memory for my computer instead of the application? Micaël. Quote
