lvb Posted April 26, 2008 Report Posted April 26, 2008 I often create typedefs that are used in various places of the front panel. One convenient technique I like is to create a classic transparent cluster, allowing me to arrange the cluster elements in any manner on the front panel. In fact, when I took the LabVIEW Intermediate course, this technique was used. The only drawback to this is if I change an element of the cluster typedef, the cluster is re-drawn on the front panel even though Autosize is set to none. IMHO, it would be nice if the cluster was not re-drawn upon adding/removing/changing data type of elements from a cluster typedef. As of now, I know no work arounds. Please feel free to comment on your experiences with this! Please see the attached picture for an example. Quote
PaulG. Posted April 26, 2008 Report Posted April 26, 2008 What version of LV are you using? I remember having similar issues in 8.20, but I don't seem to have this problem in 8.5. I just tried what you are doing in 8.5 and it seems to be working OK for me. Quote
gleichman Posted April 26, 2008 Report Posted April 26, 2008 QUOTE (PaulG. @ Apr 25 2008, 03:08 PM) What version of LV are you using? I remember having similar issues in 8.20, but I don't seem to have this problem in 8.5. I just tried what you are doing in 8.5 and it seems to be working OK for me. I have had this problem in 8.5 and 8.5.1. I'd like to see your example where this does not occure. For my project I ended up making two type defs, one for my GUI and one for SubVIs. Quote
shoneill Posted April 27, 2008 Report Posted April 27, 2008 QUOTE (gleichman @ Apr 25 2008, 09:59 PM) I have had this problem in 8.5 and 8.5.1. I'd like to see your example where this does not occure. For my project I ended up making two type defs, one for my GUI and one for SubVIs. I have also witnessed this problem with each and every version of LabVIEW I have worked with. I too find it particularly annoying. Even worse is when any Typedef constants on the DC explode when even the smallest change to their typedef is made. I know, I know, such constants should be housed in a VI, thus avoiding this problem, but it's annoying all the same. I would really like an option of displaying constants as icons....... Back to the original topic...... I can understand that a strict typedef would do this (Aren't strict typedefs also only allowed an "official" layout?), but why non-strict typedefs do this is kind of a mystery to me. I mean, changing the default value of an existing control ina typedef cluster should not explode each and every instance of that typedef in code....... As usual, just my :2cents: Shane Quote
