jgcode Posted May 24, 2008 Report Posted May 24, 2008 I want to access the color palette as a custom Shortcut RTM event in a control e.g. listbox. I just need to know the color chosen by the user and the cell that was right clicked. Any ideas?CheersJG Quote
Yair Posted May 25, 2008 Report Posted May 25, 2008 QUOTE (jgcode @ May 23 2008, 12:47 PM) Found http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=269839#M269839' target="_blank">a .net solution so I will try this. Its not LV's native palette tho. Well, I was about to point to that thread because I did post an example there of how to use the native LabVIEW palette. Of course, I don't think there is any way to get it to work nicely with the native context menus, but there are other options. Quote
jgcode Posted May 26, 2008 Author Report Posted May 26, 2008 QUOTE (Yen @ May 25 2008, 03:00 AM) Well, I was about to point to that thread because I did post an example there of how to use the native LabVIEW palette. Of course, I don't think there is any way to get it to work nicely with the native context menus, but there are other options. Thanks for your input Yen, I have coded something sub optimal but simple, but I am now experiencing http://forums.lavag.org/Event-Value-Change-Color-Box-Error-t10998.html' target="_blank">this problem. Do you post under a different name on ni forums? Quote
Yair Posted May 26, 2008 Report Posted May 26, 2008 QUOTE (jgcode @ May 25 2008, 04:30 AM) Do you post under a different name on ni forums? Yes. I was refering to http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=270051#M270051' target="_blank">this post, which should work around the issue you mentioned and save your users a click. Quote
jgcode Posted May 27, 2008 Author Report Posted May 27, 2008 QUOTE (Yen @ May 26 2008, 03:41 AM) Yes. I was refering to http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=270051#M270051' target="_blank">this post, which should work around the issue you mentioned and save your users a click. Thanks Yen! Quote
