jebus Posted June 4, 2008 Report Posted June 4, 2008 Hi, i am new to LabView and need to send a file to an email, I tryed using the SMTP Email Send File.vi , but I get this error _______________________________ Error 16502 occurred at 502 5.5.1 Unrecognized command. f21sm7832549rvb.0 Possible reason(s): LabVIEW: (Hex 0x4076) 502 Command not implemented. _______________________________ , don't know why. Can someone help please. LabView version i'm using is 8 :headbang: Quote
lraynal Posted June 4, 2008 Report Posted June 4, 2008 Could you tell us more about the values of your controls ? There is not default values... Quote
jebus Posted June 5, 2008 Author Report Posted June 5, 2008 oh yeah mail server: smtp.gmail.com recipients: my_mail@gmail.com file path: actualy I have to send a report generated in labView now I get this error: __________________________ Error 56 occurred at TCP Open Connection in NI_SMTPEmail.lvlib:SMTP Email Open Session.vi:2->NI_SMTPEmail.lvlib:SMTP Email Send File Charset.vi:1->NI_SMTPEmail.lvlib:SMTP Email Send File.vi->mysend.vi Possible reason(s): LabVIEW: The network operation exceeded the user-specified or system time limit. ____________________________ thanks for your attention. Quote
Rolf Kalbermatter Posted June 5, 2008 Report Posted June 5, 2008 QUOTE (jebus @ Jun 3 2008, 09:58 PM) this is the informationmail server: smtp.gmail.com recipients: my_mail@gmail.com file path: actualy I have to send a report generated in labView thanks really appreciate your help. sometimes I get this error: __________________________ Error 56 occurred at TCP Open Connection in NI_SMTPEmail.lvlib:SMTP Email Open Session.vi:2->NI_SMTPEmail.lvlib:SMTP Email Send File Charset.vi:1->NI_SMTPEmail.lvlib:SMTP Email Send File.vi->mysend.vi Possible reason(s): LabVIEW: The network operation exceeded the user-specified or system time limit. ____________________________ The SMTP email VIS do not implement authentification. As far as I know you can't use gmail (and just about any other email provider accessible over public internet) without authentification. You could however use your ISPs SMTP server instead (if you are on a broadband connection) or your companies email server (if you are on a company internal network). Those servers usually allow unauthentificated SMTP access since you access them from the internal network and therefore should be considered trustable. Rolf Kalbermatter Quote
jebus Posted June 6, 2008 Author Report Posted June 6, 2008 hello rolfk, thanks for your help,i tried using my isp smtp but it didn't work, so i downloaded an example from OpenG called OGIC_SMTP, and i get this under server response: when using smtp.gmail.com ___________________________ SERVER: 220 mx.google.com ESMTP k41sm3958055rvb.3 CLIENT: HELO localhost SERVER: 250 mx.google.com at your service CLIENT: MAIL FROM:<> SERVER: 530 5.7.0 Must issue a STARTTLS command first. k41sm3958055rvb.3 CLIENT: RCPT TO:<armesa2@gmail.com> SERVER: 530 5.7.0 Must issue a STARTTLS command first. k41sm3958055rvb.3 CLIENT: DATA SERVER: 530 5.7.0 Must issue a STARTTLS command first. k41sm3958055rvb.3 CLIENT: QUIT SERVER: 502 5.5.1 Unrecognized command. k41sm3958055rvb.3 ___________________________ when using cablered.com.mx, my isp ___________________________ SERVER: 220-qwerty.transit-it.com ESMTP Exim 4.68 #1 Thu, 05 Jun 2008 03:00:06 -0500 CLIENT: HELO localhost SERVER: 220-We do not authorize the use of this system to transport unsolicited, CLIENT: MAIL FROM:<> SERVER: 220 and/or bulk e-mail. CLIENT: RCPT TO:<armesa2@gmail.com> SERVER: 250 qwerty.transit-it.com Hello 201.160.178.253.cable.dyn.cableonline.com.mx [201.160.178.253] CLIENT: DATA SERVER: 250 OK CLIENT: QUIT SERVER: 550-"JunkMail rejected - 201.160.178.253.cable.dyn.cableonline.com.mx ___________________________ Quote
Jim Kring Posted June 6, 2008 Report Posted June 6, 2008 QUOTE (jebus @ Jun 5 2008, 12:26 AM) hello rolfk, thanks for your help,i tried using my isp smtp but it didn't work, so i downloaded an example from OpenG called OGIC_SMTP, and i get this under server response: when using smtp.gmail.com ___________________________ SERVER: 220 mx.google.com ESMTP k41sm3958055rvb.3 CLIENT: HELO localhost SERVER: 250 mx.google.com at your service CLIENT: MAIL FROM:<> SERVER: 530 5.7.0 Must issue a STARTTLS command first. k41sm3958055rvb.3 CLIENT: RCPT TO:<armesa2@gmail.com> SERVER: 530 5.7.0 Must issue a STARTTLS command first. k41sm3958055rvb.3 CLIENT: DATA SERVER: 530 5.7.0 Must issue a STARTTLS command first. k41sm3958055rvb.3 CLIENT: QUIT SERVER: 502 5.5.1 Unrecognized command. k41sm3958055rvb.3 ___________________________ when using cablered.com.mx, my isp ___________________________ it says something about not authorizing, after a while it shows this: SERVER: 451-The server has reached its limit for processing requests from your host. CLIENT: HELO localhost SERVER: 451 Please try again later. CLIENT: MAIL FROM:<> ___________________________ FYI, gmail requires TLS (SSL), which is not supported by the OpenG SMTP VIs. You might be able to get the OpenG SMTP VIs to work in conjunction with Stunnel (Universal SSL Wrapper), but I have never tried. The setup is non-trivial, but there are some examples, like this one, that can be found if you google "Stunnel gmail". good luck, Quote
Rolf Kalbermatter Posted June 6, 2008 Report Posted June 6, 2008 QUOTE (jebus @ Jun 5 2008, 03:26 AM) hello rolfk, thanks for your help,i tried using my isp smtp but it didn't work, so i downloaded an example from OpenG called OGIC_SMTP, and i get this under server response: when using cablered.com.mx, my isp ___________________________ SERVER: 220-qwerty.transit-it.com ESMTP Exim 4.68 #1 Thu, 05 Jun 2008 03:00:06 -0500 CLIENT: HELO localhost SERVER: 220-We do not authorize the use of this system to transport unsolicited, CLIENT: MAIL FROM:<> SERVER: 220 and/or bulk e-mail. CLIENT: RCPT TO:<armesa2@gmail.com> SERVER: 250 qwerty.transit-it.com Hello 201.160.178.253.cable.dyn.cableonline.com.mx [201.160.178.253] CLIENT: DATA SERVER: 250 OK CLIENT: QUIT SERVER: 550-"JunkMail rejected - 201.160.178.253.cable.dyn.cableonline.com.mx ___________________________ Jim answered about gmail. That about your ISP I'm not sure. For some reasons the server considers your attempt to send data as Junk Mail. Why that would be I have no idea. Technically there seems no reason to believe that the communication did not proceed right. Maybe that you should use a FROM: address in your attempt??? Maybe cableonline requires a specific procedure??? I'm afraid you will have to ask there about this, as painful it might be to get a support person from an ISP that even understands what you are talking about. Rolf Kalbermatter Quote
Jim Kring Posted June 6, 2008 Report Posted June 6, 2008 QUOTE (rolfk @ Jun 5 2008, 05:05 AM) Jim answered about gmail. That about your ISP I'm not sure. For some reasons the server considers your attempt to send data as Junk Mail. Why that would be I have no idea. Technically there seems no reason to believe that the communication did not proceed right. Maybe that you should use a FROM: address in your attempt??? Maybe cableonline requires a specific procedure???I'm afraid you will have to ask there about this, as painful it might be to get a support person from an ISP that even understands what you are talking about. Rolf Kalbermatter Maybe the ISP requires http://en.wikipedia.org/wiki/POP_before_SMTP' rel='nofollow' target="_blank">POP before SMTP -- requiring a log in to the POP server right before a log in to the SMTP server. Quote
jebus Posted June 20, 2008 Author Report Posted June 20, 2008 HOW I DID IT: I installed an SMTP server in my computer called QK SMTP Server. Then I used one of the VI's from Labview to send mail, with server name as 127.0.0.1. In the recipient I had to use an email account from budweiser, mybudweiser.com, wich was the one that didn't rejected my emails as SPAM, thank you budweiser :thumbup: , other emails you can use are from freemail.lt To everybody who tried to help me, thank you, respect. :worship: . Quote
Rolf Kalbermatter Posted June 20, 2008 Report Posted June 20, 2008 QUOTE (jebus @ Jun 18 2008, 11:54 PM) HOW I DID IT: I installed an SMTP server in my computer called QK SMTP Server. Then I used one of the VI's from Labview to send mail, with server name as 127.0.0.1. In the recipient I had to use an email account from budweiser, mybudweiser.com, wich was the one that didn't rejected my emails as SPAM, thank you budweiser :thumbup: , other emails you can use are from freemail.lt To everybody who tried to help me, thank you, respect. :worship: . And now with everybody knowing that this server is an open proxy it will either be changed to require login soon or it will end up on every single blacklist on this planet, resulting in you not being able to send your LabVIEW mail to many recipients, since they will often use those blacklists to filter out incoming mail for spam. I know our servers are configured to filter out mail originating from IP adresses on those blacklists. Much easier and better would have been to point your local email server to proxy for you to your ISP. Your email server should certainly be able to use proper authentification to contact your ISP SMTP server so that you have a hopefully firewalled to the internet, open SMTP server on your local network that will allow your LabVIEW program to contact it without authentification and will take care of the authentification towards the ISP instead. Rolf Kalbermatter Quote
