Replacement to Picture Control
Some one knows about an activeX or dotNET control that can display images at a higher frame rate then the picture control. Currently I use the picture control to display 2d array of RGB value (32bits) as fast as I can, but I use Flatten Pixmap.vi and it takes 30ms to process my 640x480 image and it take a lot of CPU time. Is there other way to do this?
Thanks
Dany
QUOTE (AndyDm @ Jun 12 2008, 01:34 PM)
You can use IMAQ Draw from IMAQ Vision. As far as I know IMAQ Vision license is not required for this function.
Andrey.
I can't use IMAQ because i'm using a beta version of LabVIEW
Dany
Dany
Well, then you can use Windows GDI functions for display. But this will require a bit more programming work with WinAPI.
Andrey.
