LAVA 1.0 Content Posted June 13, 2008 Report Share Posted June 13, 2008 Some one knows about an activeX or dotNET control that can display images at a higher frame rate then the picture control. Currently I use the picture control to display 2d array of RGB value (32bits) as fast as I can, but I use Flatten Pixmap.vi and it takes 30ms to process my 640x480 image and it take a lot of CPU time. Is there other way to do this? Thanks Dany Quote Link to comment
AndyDm Posted June 13, 2008 Report Share Posted June 13, 2008 You can use IMAQ Draw from IMAQ Vision. As far as I know IMAQ Vision license is not required for this function. Andrey. Quote Link to comment
LAVA 1.0 Content Posted June 13, 2008 Author Report Share Posted June 13, 2008 QUOTE (AndyDm @ Jun 12 2008, 01:34 PM) You can use IMAQ Draw from IMAQ Vision. As far as I know IMAQ Vision license is not required for this function.Andrey. I can't use IMAQ because i'm using a beta version of LabVIEW Dany Quote Link to comment
AndyDm Posted June 13, 2008 Report Share Posted June 13, 2008 ZITAT(daal @ Jun 12 2008, 07:48 PM) I can't use IMAQ because i'm using a beta version of LabVIEWDany Well, then you can use Windows GDI functions for display. But this will require a bit more programming work with WinAPI. Andrey. Quote Link to comment
Chris Davis Posted June 13, 2008 Report Share Posted June 13, 2008 Dany, Take a look at this post from Norm, it might have what you need. Quote Link to comment
Yair Posted June 13, 2008 Report Share Posted June 13, 2008 QUOTE (Chris Davis @ Jun 12 2008, 09:11 PM) Take a look at this post from Norm Did you mean http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=213366#M213366' target="_blank">this post? Quote Link to comment
LAVA 1.0 Content Posted June 13, 2008 Author Report Share Posted June 13, 2008 QUOTE (Yen @ Jun 12 2008, 02:21 PM) Did you mean this post? Ok it look like a nice hack but I not able to get it working how to determine the pointer in bytestream Any idea Dany Quote Link to comment
Yair Posted June 13, 2008 Report Share Posted June 13, 2008 QUOTE (daal @ Jun 12 2008, 10:37 PM) how to determine the pointer in bytestream Look at the link Chris added. Quote Link to comment
LAVA 1.0 Content Posted June 13, 2008 Author Report Share Posted June 13, 2008 QUOTE (Yen @ Jun 12 2008, 03:43 PM) Look at the link Chris added. Ok i don't saw that Chris have edited is post I take a look at it Thanks Dany Quote Link to comment
LAVA 1.0 Content Posted June 13, 2008 Author Report Share Posted June 13, 2008 It work great. I pass from 20fps 60% of CPU to 30fps 10% of CPU it's much better that way. Thank you all for the reply, and thank you Norm for the hack Dany Quote Link to comment
